T-5 Question
  • Thread starter Thread starter Seanmay1
  • Start date Start date Jan 24, 2008
Seanmay1
47
Conyers, GA
Jan 24, 2008
  • Jan 24, 2008
Well the guy i bought my car from had a dyno sheet and the 302 is making about 360 lbs of TQ, have receipts saying the car has a ford motorsports T-5, i looked them up and they are rated at 330 TQ will that trans live behind that motor? The reason i ask is because it makes a wining noise sometimes, usually in 5th gear on the highway over 70mph, car has 3.73 gears to if that matters.
88mouse
630
Mooresville nc
Jan 24, 2008
  • Jan 24, 2008
Not for very long. Just be easy on 3rd gear.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Jan 24, 2008
  • Jan 24, 2008
As long as you're not beating on it (and assuming that it wasn't abused before you got it), it should last a good long time.
Is the whining coming from the transmission or the rear end?
Seanmay1
47
Conyers, GA
Jan 24, 2008
  • Jan 24, 2008
It seems like its coming from the trans, what options do i have for a better trans that wont kill my pockets? Could i get that one rebuilt by a local shop or would it be better to buy a stronger trans from somewhere?
Seanmay1
47
Conyers, GA
Jan 24, 2008
  • Jan 24, 2008
Actually i just looked back over all the paperwork i have on the car, 247 HP @ 4k RPM 345 TQ @3500 RPM, car really doesn't make good power over 5k RPMs i think it needs a bigger cam
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 24, 2008
  • Jan 24, 2008
with the lack of hp and pretty good torque down low I would say yes to the cam swap
Seanmay1
47
Conyers, GA
Jan 24, 2008
  • Jan 24, 2008
I'm gonna save up and swap the upper and lower intake, and get a good cam i hope that will give me some better power numbers, bad part is then it will put more stress on the tranny that already cant handle the motor, from what im looking up its going to cost me a lot to get a tranny to handle any power, and i drive the hell out of this car 50% of the time so i doubt this tranny will hold up very long
88mouse
630
Mooresville nc
Jan 24, 2008
  • Jan 24, 2008
What all is done to the motor? As of now.
Seanmay1
47
Conyers, GA
Jan 24, 2008
  • Jan 24, 2008
302 .30 over, 24# injectors, MAF conversion, 65mm throttle body, Cold Air intake in fender, Shorty headers, MSD 6AL, i just got the car, that is what i know about, no clue what pistons or cam is in the motor now, or what kind of head work was done either when it was rebuilt
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 26, 2008
#10
  • Jan 26, 2008
  • #10
Stock heads???
That's why you don't have power over 5000RPM. The heads don't breath well at that RPM.
The 24's are also slightly overkill for your combo but they are on the car now so leave em.
Seanmay1
47
Conyers, GA
Jan 27, 2008
#11
  • Jan 27, 2008
  • #11
Would it be better to get some work done to the stock heads or get a better set? I really cant see myself spending over 1k right now for a set of aftermarket heads
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 27, 2008
#12
  • Jan 27, 2008
  • #12
Stock heads blow. At least try and find some Gt-40p's. They are failrly cheap and would offer better performance but won't cure the 5000RPM breathing limit.
You get what you pay for with heads unfortunately
NKau
1,346
Jefferson, WI
Jan 27, 2008
#13
  • Jan 27, 2008
  • #13
You need an intake, cam, AND heads to really notice a difference. Depending on your power goals, the stock cam really isn't that bad either; the heads/intake are where you are giving up the most performance.
It's a bit of a misconception that the later t-5's 'can't handle' a h/c/i 302-306 c.i. motor. Guys that are breaking these transmissions are typically doing it powershifting at the track, launching their cars at 5,000+ rpm on sticky tires at the track, or doing the same out on the street.
You'll hear stories from people who have broken a bunch of them, and from others who just can't kill them. It doesn't cost you anything to find out, and with what you have planned, I think you will probably be safe. I would agree with the assessment that if you are going to be going with a hot stroker motor, or have plans for a supercharger/turbo setup in the future, you may as well invest in a better tranny now.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
