  • SN95 4.6L Mustang Tech
T-5 WORK WITH 4.6?????
  • Thread starter Thread starter KJ Hoppus
  • Start date Start date May 19, 2004
KJ Hoppus
1,008
Elk Grove CA
May 19, 2004
  • May 19, 2004
I have a 98 GT with a 4r70w tranny and I was wondering if there is anyway I could make a t-5 out of a 97 v6 mustang work in mine. Can a get a difference bell housing or flywheel. I have everything out of a 97 v6 (clutch flywheel bell housing etc). I don’t mind having an auto, but I installed a shift kit and it made no big difference and a stall converter is 700 bucks, so I am thinking about swapping it over if I could. I know I could swap in a t45, but I don’t have anything for it. Any input would be great.
T
tarch
My 8V > 4V > 2V
3,073
Redmond, WA
May 19, 2004
  • May 19, 2004
why... v6 transmissions are not nearly as good as GT
KJ Hoppus
1,008
Elk Grove CA
May 19, 2004
  • May 19, 2004
i have a t5. i agree, but i would rather use what i have than go buy something i dont because i have very little money.
Snarf
237
Lexington, KY
May 19, 2004
  • May 19, 2004
AFAIK, I think they used T5's on the early 4.6 GT's. Like from 96-98.. I could be wrong though. I would prefer the T5 or T45 over the T3650 anyday though
KJ Hoppus
1,008
Elk Grove CA
May 19, 2004
  • May 19, 2004
they used the t-45 on the gt's from 96 on. yeah i dont like the way the 3650 is eather.
J
Joel's98GT
368
central OH
May 19, 2004
  • May 19, 2004
i know a friend who has a NEW t-45 for 600. I don't think the t-5 will bolt up, different belhousing.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
May 19, 2004
  • May 19, 2004
Stock T-5 isn't that great, but you can pick up beefed up T-5(from FRPP and such) alot cheaper then beefed up T-45, T-3650 or T-56 no?
ImportEater98
708
Worcester, MA
May 19, 2004
  • May 19, 2004
or spend $1300 on a fresh TKO and put an end to the tranny problems. They are rated for 800+ hp.
H
HIGDON
241
Ft. Hood, TX
May 19, 2004
  • May 19, 2004
Just pick up a decent T-45, the can handle up to 400HP. I wish there was a way to use the T-5 as it is easier to yank for a clutch job due to the fact that the transmission is removable from the bellhousing.
Or of course upgrade with a Tremec. . . . .
KJ Hoppus
1,008
Elk Grove CA
May 19, 2004
#10
  • May 19, 2004
  • #10
i guess ill try and find a t-45 and sell the t5, what about the clutch and clutch cables and all that is it the same for a t45 as a t5?
Blue 98 GT
56
Richmond, TX
May 19, 2004
#11
  • May 19, 2004
  • #11
you just need a different bellhousing. call lakewood and see if they make a t-5 bellhousing that bolts to a 4.6 block. keep in mind that you'll need a starter for a t-5 too. I did a TKO swap and only needed a new clutch kit and fork. you will need a new transmission crossmember from a GT, meaning an auto one probably won't fit and you'll need a double hump one from a GT/cobra to accommodate your dual exhaust as opposed to one from a v6, which does not have the double hump for dual exhaust.
try this site... http://go.mrgasket.com/AskTechFormLakewood.aspx?BrandID=5&BrandSelection=6
Blue 98 GT
56
Richmond, TX
May 19, 2004
#12
  • May 19, 2004
  • #12
if you're gonna install a transmission, go ahead and buy a new clutch because it's not worth putting an old one in. i have a used t-45 for sale- $300 with most parts. i would not recommend racing on a t-5, t-45, or tr-3650 platform though. they like to break easy. if you buy parts to put the t-5 in, you'll be spending $250 on parts (clutch kit, fork, throw out bearing, possibly speedo gear) and another $250 on labor to install, not to mention the price of a new bellhousing that will connect the t-5 to the 4.6. lakewood bellhousing are about $550.
J
Joel's98GT
368
central OH
May 19, 2004
#13
  • May 19, 2004
  • #13
about stock ford trannies.
They all have thier weaknesses, t-5's are alright, i don't know much in depth about them but unabusive usage can allow them to hold up to quite a bit of power.
t-45, as a gearbox It is Stout!!! you will rarely see them break the gear box it's self, it's kryptonite is shift forks, they are cast aluminum and will not hold up to abusive throws at all, (i'm on my 3rd t-45 because of shift forks and *caugh* aggresive shiftering) being a pretty strong 6'3' 250lb. doesn't make them look any less like glass either thier syncros aren't world class either.
t-3650, the only advantage i see with it is 5th gear over drive is .62 very nice for a 4.3 gear ratio on the highway, there are going to be Multiple TSB's on this thing coming (stright from a ford service manager's mouth) he is a friend and admits to way to many problems with the t-3650.
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T
Resolved How to remove the transmission Dipstick on a 4r70W
  • TekoSn95
  • Sep 18, 2024
SN95 4.6L Mustang Tech Jun 21, 2025
TekoSn95
T
