Hi Guys,
The rear of my car is making a rubbing/grinding noise from the rear while turning and it's getting quite bad. It was stupid of me to leave it this long (a couple months) without doing anything about it.
Anyways, about 1 year ago, I had a flat tire on the driver side rear. I installed the factory spare and drove around like that for a week because I had new tires on order coming from the US. I think the shorter diameter of the spare compared to the full-size regular tire on the other side, messed up the clutches etc. in the differential. Does this sound plausible?
Now, I'm looking at a rebuild kit for the differential. I see two types. One with regular clutches (I suppose) and the other with carbon fibre clutches. Does anyone know what the difference is? Which should I get? Is there anything else I will need, besides fluid & friction modifier?
Here are links to both:
Regular: Ford Racing 8.8 RING & PINION INSTALLATION KIT M-4210-C - Steeda.ca
Carbon Fibre: Ford Racing 8.8 Carbon Fibre Rebuild Kit M-4700-C - Steeda.ca
Will both of these kits work? I know the regular one is an "installation kit" for new gears, but I assume this will be fine.
Also, what fluid would you recommend for the diff? I'm leaning towards Amsoil.
Thanks and sorry for the long post!
Matt
Matt
