MattZ281LE Founding Member Feb 6, 2000 345 1 19 Purcellville, Va Aug 14, 2007 #1 Aug 14, 2007 #1 Will the V7 YSI fit the same brackets as the T-Trim on the SN-95 Cars. How about clearance, is it physically larger? Thanks
Stanger007 Founding Member Sep 26, 2001 2,015 2 46 Baton Rouge, LA Aug 14, 2007 #2 Aug 14, 2007 #2 Anderson Ford Motorsport can answer all your questions on the YSI.
Redsnk95 Founding Member Feb 3, 2002 2,243 1 0 Houston, TX Aug 15, 2007 #3 Aug 15, 2007 #3 You will have to clearance the bracket a small amount for the YSi.
94gsl5.0 New Member Sep 7, 2004 223 0 0 seatown Aug 15, 2007 #4 Aug 15, 2007 #4 Vortech only makes one set of brackets for the sn-95. You are stuck with doing what Redsnk95 stated... I wish they made a renegade double plate setup for the sn-95 front dress.
