T4M0 computer not working
BlueBomber
38
I recently swapped a fox tranny into my 95. It's currently running off the 95 automatic ECU and seems to be ok but i've heard that i need the T4M0 to make it better. I have this computer but when i install it the car does not start. Is there a wire in the tranny harness that needs to be jumped besides the neutral safety and clutch to make it start? or is this ECU dead?
The U4/W4 trans can work but it hesitates when it thinks the auto is going to shift.
What did you do with the shift position sensor?
When you turn the key to run, do you hear the FP prime? That'd be a clue that the T4 works.
Good luck.
No it's a fox body manual tranny. Basic T-5.
Yeah i noticed that as I'm increasing RPM it'll somewhat jump at one point and hesitate and then continue increasing. Hmm I didn't notice the fuel pump but i know it turns the fan on right away and so does the fox computer. So if the fuel works u think the computer is ok?
I did not do anything with any shift position sensor! I don't even know where that is. Can it be that u think?
If your fuel pump primes or you hear solenoids under the hood buzzing, that would suggest your computer is ok for now. Now on a fox swap you have to do a little computer repinning for the starter circuit. I'm not sure if you have to on a 94-95. This could be part of the problem.
You should have the shift position sensor siting in 'Park' or 'Neutral' so the starting circuit is closed (remember on your AODE it was like this so you could not start the car in Drive).
What I would do: Pop the hatch on your underhood fusebox. lift the Starter relay just enough to expose the terminals. Use a test light or DMM and See if you have a crank signal reaching the relay. If so, see if you have a crank signal leaving the relay and heading towards the starter solenoid. If you're good there, all of your starter interlock wiring (like the gear selector switch) should be fine.
The default for the fan is to actually be on. This is done as a failsafe if the computer cannot see the temperature (the computer turns the fan *off*, otherwise it wants to run at all times). A fox computer doesnt have a means of turning on the fan (it's not wired to interface with the CCRM), which further illustrates the above-point.
Good luck.
ok well the repinning of the neutral safety and the clutch switch was done. Without that it won't even turn over.
So the car does turn over meaning that the starter is getting signal.
As for the neutral park thing i think it HAS to be ok because right now i'm starting and running the car with an auto ECU. If anything that ecu looks for the park or neutral before the manual would.
I'm lost here!
