T5 from T-bird....speedo off now
even if you have the correct driven gear on your speedo cable to compensate for a rearend gear change, the speedometer drive gear in the transmission might be different. if your speedo was correct before the transmission change, it sounds like this is your case.
Do you know what year the trans came from??
If you look inside the hole where the speedo goes, you'll see the gear. Yellow would be a 7-tooth, green is an 8-tooth and black is a rare 6-tooth.
