T5 Help
  • Thread starter Thread starter sj9ers
  • Start date Start date May 9, 2008
sj9ers
71
  • May 9, 2008
I was at the junkyard today and saw a t5 tranny behind a 2.3l 1988 Mustang. I'm looking for a t5 to put behind my 5.0 302 and was wondering if the t5 from the 2.3L is the same as the 5.0 version? and would the bell housing fit from the 2.3l?
thanks
woodsnake
1,352
15
69
Hicksville, NY
May 10, 2008
  • May 10, 2008
You could make it fit, you would not be happy with it.
http://www.moderndriveline.com/Technical_Bits/transmission_spec.htm
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 10, 2008
  • May 10, 2008
It will fit with the right bell housing and possibly a different inputshaft/bearing retainer but the bottem line is it will not last at all. The 4cyl T5s don't stand up to any real abuse.
izzy jr
76
Abilene,TX
May 10, 2008
  • May 10, 2008
I wouldn't recommend doing that! A buddy at work had a car like that and yanked out the 2.3 a dropped in a mildly build 351w, first time he got on it he fryed the clutch after swapping that out he tried it again and lost first gear, this continued for a few times before he finally swapped the tranny out .
sj9ers
71
  • May 10, 2008
I guess I'll keep on looking then. Thanks
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
May 10, 2008
  • May 10, 2008
Aside from having a different input shaft, the 2.3 specific T5s usually have steeper gear ratios to cope with the lower torque(usually) of a 2.3. Putting one behind a V8 with 300+lb-ft of torque means that the steeper ratios put more stress on the case and gears and can more easily break them.
For example, the T5 in mt '84 SVO has a 4.06 1st gear with 3.45 rears whereas the T5 in my '89 Mustang had a 3.35 1st with 3.08 gears. Some sources say the '89 5.0 got a 2.95 1st, so take it for what it's worth.
v8stang289
136
116
74
May 11, 2008
  • May 11, 2008
The 2.3 t-5 can be used, but typically wont last long as it has a lower torque capacity. It also usually has a much lower first gear, 3.97 I believe(in most cases). You also have to use a pilot bearing from a 90 mazda b2200 because the 2.3 t-5 has a different diameter input shaft. The 2.3 bellhousing will not work with the 302.
BornInAFord
199
Bend, OR 97701
May 12, 2008
  • May 12, 2008
The case(s) and sliders, however, are the same. If you can get an excellent deal on one, consider gutting it and rebuilding it with Z-spec gears (2.95 gearset), upgraded pocket bearing and counter gear stabilizer and proper input shaft and steel front bearing retainer, etc. You should then have a very good tranny that can stand quite a bit of abuse.
Daniel
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
A
2.3l t5 transmission
  • Ant_thomp
  • Mar 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 5, 2025
Ant_thomp
A
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
