T5 internal inspection
I'm going to do a T5 swap on my 93lx. I bought it used T5 locally from some guy who bought this 90 Mustang which had a front end collision. He used the 302 to swap into his 66 Mustang. He said the tranny was solid.
I have a few weeks until I do the swap. Should I remove the top cover and inspect the internals for broken pieces? Can a look inside tell me anything? Is the cover sealed with a gasket or RTV? I don't want to put it in and have to put it down again.
that's the chance you take when you buy a used t5. don't know what to tell you, but to get the top cover off, you'll need to drive the pin out of the shifter base inside the top neck of the trans where the shifter bolts to, pull that block out, then unbolt the tail housing, and slide the tailshaft out (make sure trans is in neutral first)
from there you can unbolt the top lid off, and slide it off at an angle. all that will tell you if a gear is completely fubar'd. it won't tell you the condition of the sincros, and everything else that is hidden unless you take the mainshaft out and apart and the cluster shaft out.
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550/TKO
You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160. It does not include any gears or shafts.
http://www.hanlonmotorsports.com/ also has a video on how to rebuild your T5 or Tremec. It costs about $20, and is worth every penny of it.
