Yep. I may have one, but I'd have to do some digging lol. It's easier to swap to electronic than the other way around. Mechanical speedo uses a drive gear attached to the main shaft with a small clip, which needs a small hole drilled into the hardened shaft to attach it. Very hard to drill into the main shaft! But iirc, the electronic speedo ring just slides on the shaft. I'll see if I can find one lying around.
But as I said before, you could also swap to the v6 t5 and sell yours. You'd probably come out ahead and have a stronger tranny.
Just saw your post above concerning the Summit part. For some reason, the "quote" function isn't working from my phone. Sorry for any confusion.
I don't know anything about the part you linked to. I know you used to be able to buy a "speed-cal" device which was plug & play. I think they stopped making it though. I really haven't messed with electronic speedo much, other than changing it back to mechanical lol
