Hello, I new here...hoping someone can help me with a t5 transmission rebuild. I hope its okay to piggyback on this thread.
I pulled the tranny out of my 89 5.0. The main shaft bearing surface under 3rd gear is gouged and I'm looking to replace the main shaft. I have found new and used main shafts for sale, but they all look different than mine. My main shaft has a flared tip (Not the tapered barring like on the cobras and Z trans). all others I have seen have a straight tip. I'm referring to the tip that inserts into the input shaft and rolls on the needle bearings.
No one I see selling new or used main shafts specifies a difference. Can I use a main shaft with a straight tip? If so do I need a new/different input shaft. If not where can I find an affordable replacement.
Any help you can give me is appreciated.
Your mainshaft is the oddball. That's not how a typical Mustang t5 mainshaft looks. Do you have a tag on the T-5 that can help identify it? If not, take photos of the overall case and such.
This is what the tip should look like, and also, since it's related to this thread, the mainshaft tip in this photo also has the typical galling damage that causes 1-3 gear whine
