t5 problem....HELP
  • Thread starter Thread starter twolo4u2c2
  • Start date Start date Mar 14, 2007
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
Mar 14, 2007
  • Mar 14, 2007
I have found out why the 4th gear syncro is shot.......With the reatiner in place and zero lash there is not enough room for the blocker ring to move it actually presses on the cone when tightened. The only solution I can see is using a shim behind the race to make the needed room. If anybody has or knows where I can get a t5-Z manual or blow up to help in fixing this thing I would love it. I'm gona put a call into the trans shot to see if they can help.
rd
3,316
63
109
Ocean Springs MS
Mar 14, 2007
  • Mar 14, 2007
Search for T5, the manual is out there. Its also available from Hanlon Motorsports and D&D, as well as JC Whitney. It is also available on some Jeep sites.
I used an old MM&FF article and a Chiltons Jeep book to r&r the 3-4 synchros in my Jeep T5. Pretty straightforward, and yes you have to check endplay and shim accordingly.
L
LX2NV
10
  • Mar 15, 2007
sounds like your using too much shim, are you standing the tranny on end to check the play ? for the initial assembly you want a little "preload" on the beaings, but not too much or you could easily toast the torrington bearing. when i build my trannys i assemble them a little loose...drive it for a hundred miles or so to let everytihing seat in and than reshim to as close to zero tolerance as i can get without going over, aucutally i like a "hint" of play.
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
Mar 15, 2007
  • Mar 15, 2007
its not the shim thats the problem....in the z tranny there is a cone bearing kinda like a wheel bearing between the input shaft and the main shaft. The cone and blocker ring contact BEFORE the bearing forcing the blocker ring to "press" on the cone burning it out. only solution it to press off the bearing and shim it out to giv more space for the blocker ring. dose this help understand what I'm talking about.
Quikstang
846
Orlando FL
Mar 15, 2007
  • Mar 15, 2007
www.hanlonmotorsports.com they have a few blown up pics of all the Trannys, and part numbers.. may help you out a bit.
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Mar 15, 2007
  • Mar 15, 2007
If the blocker is pushing against the input shaft with the 3-4 synchro in the neutral position, that suggests to me that the 3-4 synchro hub is not pressed onto the mainshaft far enough or the 3-4 hub is installed backwards.
When the input shaft is installed, the blocker ring should not touch at all. The bearing needles between the input and mainshaft should be what is making full contact.
Manual here.
http://www.ttcautomotive.com/English/onlineorder/downloadPro.asp?id=1
Edit, just realized you have the z-spec T-5. It's input shaft setup is a little different so i'm not 100% sure on it
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
Mar 15, 2007
  • Mar 15, 2007
I think I may have fixed it.....I removed the cone inside the input shaft and used a 1/16 inch shim under the cone. It gives me about the same movement as the 3rd gear blocker ring has. I guess we'll see when I hit 4th at 5700 RPM......LOL
thanks for all the suggestions and links, as always stangnet come thru.
D
DouglasOhio
116
Canton Ohio
Mar 16, 2007
  • Mar 16, 2007
yeah im on the same boat as mustang5l5. I would check the blocker on the 3rd gear side to see if it has too much play. This would mean you have to press the inner hub onto the mainshaft a little farther. I ran into this same problem.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 16, 2007
  • Mar 16, 2007
when I did mine , I measure the end play at like .030 and double checked it about 10 times , and put a .031 shim in it and let it ride and its been smooth as butter ever since
F
Fox T5 with big block?
  • Foxy86LX
  • Apr 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 23, 2025
nickyb
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
