As you might recall from a thread about a week or so ago, I'm trying to swap a T5 into my 66. I have a few things I have questions on..
The first concerns the speedometer cable/gear. Where do you guys find replacement speedometer gears? Also, how does the speedometer cable/sender connect to the gauge (most importantly, does anyone know what modifications I'm going to need to connect my 66's speedometer to the T5? Will my C4 automatic parts work?
I also need a reliable T5 speedometer gear calculator... I believe my 89 T5 has a 7 tooth drive gear,a nd one calculator said with my tires (225 60r15), rear ratio (3.25), and assuming 1000 revs/mile that I'd need a 17 tooth gear. Sound right?
The second has to do with my new Pro 5.0's shifter stop screws. On the advice of people here (and elsewhere), i got this shifter. Many people cited that though its a smoother shifter, its also almost a necessity because the stop screws stop you from overshifting and damaging the forks. How do you set these screws?
Thans a ton, it is very much appreciated...
