T5 rebuild masters
  • Thread starter Thread starter 89redvert
  • Start date Start date Jun 18, 2004
89redvert
29
Memphis
Jun 18, 2004
  • Jun 18, 2004
I had a friend's dad rebuild my T5. I have not installed it yet because something is screwy. When I move through all of the gears the transmission acts as if it is in neutral at the input shaft and the tailshaft. Is this correct. I can put the transmission in 1, 2, 3, 4, and 5th gear and move the input shaft as if it were in neutral. Same thing with the output shaft. This also does the same thing in reverse. I can put it in reverse and the input and output shaft spin as if it were in neutral. Did he put it back together incorrectly?
Thanks
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 18, 2004
  • Jun 18, 2004
why are you spinning the shafts?
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 18, 2004
  • Jun 18, 2004
Thanks
so what youre saying is that if you turn the input shaft and the shifter is in first gear the tail shaft doesnt turn? if that is the case than yes, something is seriously wrong with that transmission
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
F
T5 transmission questions
  • Forddestroyer96
  • Aug 27, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 27, 2025
Forddestroyer96
F
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
