T5 rebuild?
  • Thread starter Thread starter David89gt
  • Start date Start date Nov 14, 2012
First Prev 2 of 2
MFE92
1,094
373
124
Phoenix
Nov 18, 2012
#21
  • Nov 18, 2012
  • #21
No need to take the console out. All you need to do is take the shifter plate off, and either file or dremel some clearance into the panel underneath to make it easier to reach the front shifter bolts.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Nov 18, 2012
#22
  • Nov 18, 2012
  • #22
yep, just clearance the plastic a bit
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 18, 2012
#23
  • Nov 18, 2012
  • #23
Shifter bolts or the rubber gasket? My buddy just takes the two bolts on the shifter handle off..
MFE92
1,094
373
124
Phoenix
Nov 18, 2012
#24
  • Nov 18, 2012
  • #24
I take the whole shifter off, that way I can fill it through the shifter hole after the trans is in place.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 18, 2012
#25
  • Nov 18, 2012
  • #25
Yes.. That is why I take the shifter off also.. Much easier than pumping it up into the fill hole.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Nov 18, 2012
#26
  • Nov 18, 2012
  • #26
Why not just fill it on the ground put a plug in the tail shaft ?
Reactions: 88LX5.Oh
MFE92
1,094
373
124
Phoenix
Nov 18, 2012
#27
  • Nov 18, 2012
  • #27
Because I don't like taking a Mercon bath when it's time to put the driveshaft in, and I don't always have the luxury of having the car tilted far enough forward to keep that from happening.
srtthis
5,129
1,666
204
Maryland
Nov 19, 2012
#28
  • Nov 19, 2012
  • #28
that one i can understand... i got a bath in it once when i was changing the valve body is a guys lightning. ford in all there wisdom didnt put a drain plug on the pan of the 2wd 4R100's so you got to do the unbolt a corner and drain some then try and drop a pan full of fluid... i lost.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 19, 2012
#29
  • Nov 19, 2012
  • #29
I have put the shaft in before I installed the trans to keep the fluid in. But I would rather fill it from the shifter hole.. Little more work but easier for me..
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 19, 2012
#30
  • Nov 19, 2012
  • #30
Yeah the 4r70w has no drain plug in the pan either.. I over filled one by accident and had to crack the pan to let some out very slowly.. That was a pain in the ass.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Nov 19, 2012
#31
  • Nov 19, 2012
  • #31
Wow...you guys are totally getting hung up on that 1 hour thing. My very next sentence actually told him to pay the $800 since I thought he might not have the means to do the job himself
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 19, 2012
#32
  • Nov 19, 2012
  • #32
Yeah really hung up.. Just having a conversation.. If you have nothing to add that's fine
88LX5.Oh
1,442
205
94
Arkansas
Nov 19, 2012
#33
  • Nov 19, 2012
  • #33
In the early days of the E40D (4R100's predecessor) they had a drain plug. But I guess too many people kept stripping them out so Ford did away with them. But, take all the pan bolts out except for the back 3 and let the whole pan tilt down, then slowly loosen the back 3 to let the pan tilt even farther. Then once you're almost to the end of the bolts just push the pan back up then take out the last three bolts. You end up with maybe 2 quarts in the bottom of the pan. And as you know, 2 quarts in a 4R100 pan isn't much.
88LX5.Oh
1,442
205
94
Arkansas
Nov 19, 2012
#34
  • Nov 19, 2012
  • #34
What we do at my shop is we have a small container with nipples on both sides at the top with hoses coming out of them. Shove one down the dipstick tube and the other you take the brake booster hose off and use the engine vacuum to suck out the trans fluid. Real simple set up
srtthis
5,129
1,666
204
Maryland
Nov 19, 2012
#35
  • Nov 19, 2012
  • #35
Yea... The 4wd pan had a plug on it. The 2wd on the other hand didn't. Most guys swapped the pans out so I just started punching holes with a punch. Made things easier
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Nov 20, 2012
#36
  • Nov 20, 2012
  • #36
Good idea..
First Prev 2 of 2
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
