t5 sensor ?
  • Thread starter Thread starter Jaswir
  • Start date Start date May 22, 2007
Jaswir
578
Orlando, FL
May 22, 2007
  • May 22, 2007
whats the sensor or electrical thing called on top of the trans cover? just got my t5 today and it didnt have one?
also how much play on the shaft is acceptable?
88mouse
630
Mooresville nc
May 22, 2007
  • May 22, 2007
i think the one on top is a saftey switch.
Jaswir
578
Orlando, FL
May 22, 2007
  • May 22, 2007
anyone know where i can get one at?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 22, 2007
  • May 22, 2007
It is the neutral safety switch. It is for the computer to know the trans is in neutral before you dump the engine running codes. See item #6 in the drawing below.
No switch and you get a code 67.
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code may prevent you from running the Key On Engine On tests. You can generally ignore this code, since it has no effect on engine performance.
The computer wants to make sure the A/C is off due to the added load on the engine for the engine running tests. It also checks to see that the transmission is in Neutral and the clutch depressed (T5, T56, Tremec 3550 & TKO)). This prevents the car from being driven while the computer is in test mode. Key On Engine Running test mode takes the throttle control away from the driver for several tests. This could prove hazardous if the computer was jumpered into test mode and then driven.
The NSS code 67 can be bypassed for testing. You will need to temporarily ground pin 30 to the chassis.
Jaswir
578
Orlando, FL
May 22, 2007
  • May 22, 2007
anyone know where i can buy one at???
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 22, 2007
  • May 22, 2007
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com for parts
Jaswir
578
Orlando, FL
May 23, 2007
  • May 23, 2007
anyway to bypass it untill i get one in the mail... because i really wanted to do the swap this weekend
HISSIN50
34
129
May 23, 2007
  • May 23, 2007
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 23, 2007
  • May 23, 2007
Either my post was too complicated to be understood or Jaswir needs to re-read it and ponder its meaning...
Waz900
41
Sewell, New Jersey
May 23, 2007
#10
  • May 23, 2007
  • #10
I'm just trying to clarify something. The other end of that switch is on an AOD harness too correct? You mentioned that the car has to be in neutral or park so that leads me to believe that it is on both. I'm doing the swap around tax time next year and I was worried about if I forget to leave the car in neutral when I start it. This switch shouldn't allow the car to start correct? I really don't want to drive through my garage...
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 23, 2007
#11
  • May 23, 2007
  • #11
On a 5 speed the switch has nothing to do with the starter circuit. It is strictly for the computer. See my post and the code 67 test path in it.
Starter circuit wiring diagram.
Diagram courtesy of Tmoss &Stang&2birds
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars.
See http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
Waz900
41
Sewell, New Jersey
May 23, 2007
#12
  • May 23, 2007
  • #12
OK, I am not very good at reading those diagrams but i'm pretty sure I get what you're saying. Thanks!
Jaswir
578
Orlando, FL
May 23, 2007
#13
  • May 23, 2007
  • #13
yea sorry im a lil slow sometimes!
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Monday at 12:38 PM
Fox 5.0 Mustang Tech Tuesday at 7:31 PM
mikeah
