t5 shifter in neutral...
  • Thread starter Thread starter Foxfan88
  • Start date Start date Oct 2, 2005
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Oct 2, 2005
  • Oct 2, 2005
ok i was tinkering with my t5 in the garage, going through the gears and it all feels good.
But i notcied, when the shifter is in neutral, you know how on 5 speeds you can move the shifter left and right in neutral, and it will go back to the center. Well mine sorta of does. It kind of gets hung up a bit. Is this due to just an old tranny?? lack of lubrication???
its not like it gets stuck to the left or right, it just doesnt FREELY go back
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Oct 2, 2005
  • Oct 2, 2005
With a stock shifter, the transmission will probably not self-center. And yes, having transmission fluid on the gears would help.
88 Fox GT
1,674
Iowa
Oct 2, 2005
  • Oct 2, 2005
Having fluid definitely helps. The age and condition of the transmission are both factors as well.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Oct 2, 2005
  • Oct 2, 2005
yeah i think its probably the fluid. when it was together when i got it self centered well. Since then the fluid has been drained...
thanks guys...
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Oct 2, 2005
  • Oct 2, 2005
probably a little of both.
fox racer
577
Staten Island, NYC
Oct 2, 2005
  • Oct 2, 2005
the shifter is the thing that self centers the tranny. aftermarket shifters (any kind) will help this out the most. mine does the same thing, 5th to center is tight and quick but 1st to center is a little sluggish.
Euphoric306
905
  • Oct 3, 2005
the shifter from the factory doesn't have centering springs (forgot the real name) so you can move the shifter between 1-2 and it will stay there. aftermarket shifters have these springs like newer cars that automatically move the shifter between 3-4 when pressure is released, it helps with misshifts into third gear.
dont worry your tranny is fine, it did the same thing with 8 miles on it
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
