I'm about to install a t5 in my 66. Those of you that have done this, what setup are you using for the clutch... Z bar or cable? What type of speedo cable should I use? I heard I should use one from an automatic. Also if anyone has a t5 out of their car I need a measurement. I need to find out how long the throw out bearing retainer is on a V8 t5, 93 and older. the reason is I have t5 from a 96 V6. I swapped out the input shaft but the throw out bearing shaft is too long. Any help would be great! Thanks!
