  • 1994 - 1995 Specific Tech
T5 swap question
  • Thread starter Thread starter Synned
  • Start date Start date Feb 14, 2006
1 of 2 Next Last
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Feb 14, 2006
  • Feb 14, 2006
I'm about to do this swap...I have a couple questions for anyone.
First, I have a remote starter...so whats going to have to be done for this to still work? I assume a bypass something is needed.
Second, how hard is this swap? Me and my dad have little mechanic experience, I mean I read the tutorials I know everything it's talking about, just not a lot of hands on experience, we have all the time we need to finish it.
Anyone have a guess of how much labor this would be to do?
I found some writeups...allformustangs and wc mustangs, are there any other good ones?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Feb 14, 2006
  • Feb 14, 2006
http://www.allfordmustangs.com/Detailed/25.shtml
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 14, 2006
  • Feb 14, 2006
the hardest part of the entire swap is cutting the transmission tunnel for the manual and fitting the pedals.....everything else is simple.
95Vert
1,785
North Mexico (deep south Texas)
Feb 14, 2006
  • Feb 14, 2006
Synned
Mar 31, 2005
991
Philly
Feb 14, 2006
  • Feb 14, 2006
95Vert said:
BDAWK2002
139
Old Bridge N.J.
Feb 14, 2006
  • Feb 14, 2006
Swapp is easy.Hardest part is putting in the pedals.The whole thing will go well if you have a good set of tools and some time.Dont try and bang it out in one day.
At1Maverick69
220
San Leandro, Cali
Feb 15, 2006
  • Feb 15, 2006
not sure if it's gonna be the same as the foxes when converting, but I agree with the others, the pedals are gonna kick ur @ss, good luck. and BTW, I didn't have to swap computer on mine 90 when I did it, what's the deal with SN95's?
9
95_5.0_stang
172
Lansing, MI.
Feb 15, 2006
  • Feb 15, 2006
It's a pretty easy swap. Pedals aren't as bad as some tell you they are. Just unbolt part of the steering shaft under the dash. I didn't have to drop the column or anything. Just gotta give a couple convincing words to it, and voila it's in.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 15, 2006
  • Feb 15, 2006
i didnt even undo the steering shaft. i worked around it.
Synned
Mar 31, 2005
991
Philly
Feb 15, 2006
#10
  • Feb 15, 2006
  • #10
Thanks guys. The reason the SN95 computer has to be changed is because it has the AOD-E and the car will hesitate at the time the computer thinks its time to shift by pulling out timing.
Okay, so the manual trans assembly goes like ths:
Pilot bearing attaches to the crank, and then the flywheel, first half of the clutch, other half of the clutch, pressure plate, and trans? Is there a website or someone that can explain all this to me?
95Vert
1,785
Feb 15, 2006
#11
  • Feb 15, 2006
  • #11
I just wanted to subscribe.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 15, 2006
#12
  • Feb 15, 2006
  • #12
To further clarify that, it's not only because the SN95 has the AODE, but because the EEC also controls the AODE and its shift points. I believe this can be compensated for/disabled by using a TwEECer or a chip, but otherwise as Synned said, it pulls timing when it believes it's shifting the auto.
M
miller92063
253
Nebraska
Feb 15, 2006
#13
  • Feb 15, 2006
  • #13
NO CUTTING IS NEEDED, AT LEAST NOT WITH THE TKO. AND THE CLUTCH PEDALS IS BY FAR THE WORST PART OF IT.
TAKE OUT THE DRIVERS SEAT FOR THE EXTRA ROOM!!!! TRUST ME. WELL WORTH THE TIME TO TAKE IT OUT. I SPENT PROBLY TWO HOURS ON THAT DAMN THING IT KICKED MY A$$
THE REST WAS SIMPLE.
M
miller92063
253
Nebraska
Feb 15, 2006
#14
  • Feb 15, 2006
  • #14
this should explain the process to you
Synned
Mar 31, 2005
991
Philly
Feb 15, 2006
#15
  • Feb 15, 2006
  • #15
Did you guys need a lift when you did it?
It sounds like its impossible to do on jack stands.
BTW, my auto is really starting to **** on me.
ITS GONE. Today driving all of a sudden feels like its in neutral, then kicks back. Sometimes starting off from a light I have nothing, then jumps into gear. Sometimes it goes into OD when it should be in 2nd...its all ****ed up man.
fox racer
577
Staten Island, NYC
Feb 15, 2006
#16
  • Feb 15, 2006
  • #16
Synned, trust me, its a very easy swap. just the first time around, especially if you dont have alot of hand on exp, its gunna take time. Might i suggest a way of doing it?
Day 1: Take everyhitng out. H-Pipe, D/S, AOD, pedals all that crap. Then do any prepping you want (cleaning stuff, modifying the crossmember ETC)
Day 2: Do the pedals FIRST. Get that crap out of the way! Its annoying, but not impossible.Take out the driver side seat and drop the steering column. Then put in the clutch tranny etc. Now, you can finish up all the litle crap, or move on to a 3rd day.
Day 3: Make sure your tranny is filled, check and double check eletrical connections (not many, like 2-3 TOPS) double check all bolts (D/S bolts and Flywheel bolts should be thread locked), put in the exhaust, adjust the clutch. Now take her for a spin and clean up!
I feel ya on the neutral feeling. my tranny did the same thing... It was a bad TV cable. HINT: (at least in NYC) for bulk pickup, the garbage men take AODs If you want, i can go into detail for EVERYTHING you need to kno, just pm or email me. Where are you located? maybe i can help you out... depending. BTW: mine was doen in my driveway, with 1 jack and 2 jack stands.
Synned
Mar 31, 2005
991
Philly
Feb 16, 2006
#17
  • Feb 16, 2006
  • #17
Thanks man, I really think we are going to do it. Im going away for a couple days and when I get back I think its going to get ordered. If I have any questions I'll sure to let you know, thanks a lot man.
SeriousSN95
74
daytona beach FL
Feb 16, 2006
#18
  • Feb 16, 2006
  • #18
http://www.stangparts.com/howto/mmff/t5/ go there itll help u out alot! i did my full swap in about 4 hours (not included taking all the aode stuff out) just take the seat out for extra room on the pedal assembaly and pm me if u got any questions, i did mine about 2 weeks ago and it was easy!
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Feb 16, 2006
#19
  • Feb 16, 2006
  • #19
with the t5, you need to extend the hole in the trans tunnel at the front by about 1/2" to clear the tranny. maybe the tko is different, but i am going by my personal experience with swapping in the t5.
urban96
3,464
Syracuse, NY
Feb 16, 2006
#20
  • Feb 16, 2006
  • #20
yup, i trimmed out about 1/2" too
1 of 2 Next Last
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
