t5 swap questions
njoliver
259
Columbus OH
alright I bought a t5 with most of the stuff for the swap I rebuilt t5 it was total junk (new mainshaft,2nd gear, 1-2 shift fork, and complete overhaul kit, the input shaft was screwed up also were the pilot bearing rides so I tried to grind it down with a dremel but I dont know if it will work it seems a little loose on the pilot bearing. well as far as the swap goes I want know if I need a different computer, different driveshaft and a different crossmember
your ECM & DS will be fine,although it would be a great time to switch to an Aluminum DS while you have everthing apart. as far as the crossmember, I think it will be fine also but not 100% sure on that. try using the search feature here on SN & see what you find. lot's of invaluble info here on this site. good luck with your stang!
the only thing I need to find is the pedal assembly and Im not sure if I the pivot ball I am not quite sure what that is
Ok, the pivot ball is in the bell housing, it is what the clutch fork "pivot's on".
Also, I have a full pedal assembly (w/an aluminum quadrant already installed on it) out of my 91 fox that I am slowly parting out. haven't pulled it yet but it wouldn't take long. PM if you are interested in it. I also have other 5spd swap stuff from the same car. hd clutch,aluminum flywheel,ect.....less than 2k on the parts. let me know if you need anything.
