T5 swap trouble
  • Thread starter Thread starter lancec2c30
  • Start date Start date Nov 9, 2009
lancec2c30
570
Washington
Nov 9, 2009
  • Nov 9, 2009
I finally got the engine and trans in my coupe. Motor mounts and transmission mount are all attached, but I noticed the 2 front bolts on the shifter base plate are underneath the trans tunnel.
The car was an auto, this isn't normal is it? Because I wouldn't be able to change shifters without dropping the trans the way it sits now.
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Nov 9, 2009
  • Nov 9, 2009
yup, thats what happens, you gotta cut out that front section of the tunnel a bit. if youve got the lower boot, use that as a guide, cut the section out, drill a couple holes, throw in some speed nuts (or w/e you want to call them) and bolt it down.
I_AM_CANADIAN
189
B.C.
Nov 10, 2009
  • Nov 10, 2009
Ditto, ran into the same issue, just cut out enough to get a socket to fit over the shifter plate bolt. The rubber shifter boot fits right over with a couple of self tapping screws.
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
