T5 swap?
  • Thread starter Thread starter gritchy5.0
  • Start date Start date Sep 30, 2010
gritchy5.0
69
Rock Island IL
Sep 30, 2010
  • Sep 30, 2010
will a t5 from a 87 turbo coupe bolt directly to my 87 lx?
stykthyn
5,232
2,652
223
gainesville
Sep 30, 2010
  • Sep 30, 2010
You will need a 5.0 bellhousing and a spacer to go on the input shaft. I forget the part number but its the one that goes on a diesel ranger.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 1, 2010
  • Oct 1, 2010
The 4 cylinder T5 trans has a 3.97:1 first gear so, it will wind up very quickly. If you blink you will have hit the redline in first gear before you know it. It also has a lower torque limit spec, 235 Ft/Lb, so it may break easier than a V8 T5. The pilot shaft is smaller, so you will need a different pilot bearing.
The pilot bearing you need is for a Ford Ranger diesel from AutoZone part #14672 - hope this helps!!!
gritchy5.0
69
Rock Island IL
Oct 1, 2010
  • Oct 1, 2010
thanks for the info guys. ive decided not to go that route. back on the hunt....
skunk21
1,203
Taxachusetts
Oct 1, 2010
  • Oct 1, 2010
If you come across a T5 that you are not sure what it came out of or ratios here is a list of T5's by ID # to help identify it. might come in handy.
Identification Key to Borg-Warner T5 transmission ID Tags
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
