Not true. There is a difference between the 4 cylinder T5 and a V8 world class T5.Thenemesis said:T5 is a T5
evilwater said:what about using the sincros out of the thunderbird to put into the mustang will any of them fit???
evilwater said:so how do i tell if the t5 out of the mustang is a world class or a non world class tranny without ripping it apart??? is there a part number that i can use to find this out???
Check the tag which is where the bell housing bolts up (I'm pretty sure that's where it is.) It will have a # that starts with 1352- write the # down and go to www.ddperformance and click on "Ford WC Trans ID" to check it. That will tell you what the trans was originally in.evilwater said:so how do i tell if the t5 out of the mustang is a world class or a non world class tranny without ripping it apart??? is there a part number that i can use to find this out???
TOPLESS92 said:The input shaft is smaller on a 4 banger T-5 . I saw the 2 side by side when I bought mine recently . The diameter is smaller . You could switch out the shafts but it's not cost effective .
