t5 trans fluid
  • Thread starter Thread starter one2gamble
  • Start date Start date Jul 18, 2004
one2gamble
902
Monterey
Jul 18, 2004
  • Jul 18, 2004
what kind of fluid does the t5 take and what are some recomendations of brands etc?
R
Ronstang
1,294
Houston Texas
Jul 18, 2004
  • Jul 18, 2004
As far as I know it uses automatic transmission fluid and the latest Mercon level should be fine. Some transmissions like the Tremec (at least the first gen ones) use a special fluid that is rather expensive and available at the Chevy dealer.
G
geegee
2,015
near Oklahoma City, OK
Jul 19, 2004
  • Jul 19, 2004
Uses Dextron/Mercon fluids. Any name brand is okay but always top off with the same brand you select for the first fill. Elsewise drain and refill. You need this fine runny stuff so it penetrates very small orifices drilled in the tranny gears. You also need good seals and a yoke in good condition (no grooves) to keep this stuff off your driveway. Never use gear oil as it won't lubricate this tranny.
Glen's 1965 5.0
477
Tomball,Texas
Jul 19, 2004
  • Jul 19, 2004
Fluid
The expensive stuff Ronstang is speaking about is GM syncromesh. It is good stuff. The Mercon II or equivalent fluid will work. It takes 2 ½ quarts.
Other synthetic fluids that I have used is Redline and Mobile One Synthetic ATF.
I have only used the synthetic fluids on T5 that I have rebuilt with the new upgraded syncros. I don’t know how it would work with the older style syncros that were paper lined.
BobV
20+ Year Stangneter
May 18, 2003
474
Leavenworth, KS
Jul 19, 2004
  • Jul 19, 2004
Also, it depends on which T5 you have!!!
The early (non-WC / 83-84) T5's take regular 90W...
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
