T5 Trans Noise?
Scott7512
153
Branchland WV
93 LX 5.0
I have had the car for three years now and it's always had a noise that sounded like exhaust noise to me but it was only there on part throttle while in gear and moving. I very seldom drive it for more than 10 mile at a time so I thought I would get around to fixing it eventually. But I decided to hit mustang week this year. A little over 500 miles and my son and I made it today.
Problem is now the noise is louder. I now think it has something to do with the transmission. Any ideas what it might be?Should I be worried about getting back home?
Does it change with the car is in neutral? How about with the clutch in vs out?
If it sounds like an exhaust leak it could just be that the H pipe is loose at the header flanges.
Sounds like it may be a throw out bearing. The trans would have to come out to replace it....but the bell housing and clutch can stay. Exhaust dropped, trans mount bolts, cross member, speedometer cable, neutral switch, reverse switch, driveshaft, shifter boot, shifter arm, shifter lower rubber boot, clutch cable, 4 bolts from the trans to bell housing, clutch fork will be laying in the bell housing with the throw out bearing sitting in it.
If the clutch isn't adjusted right it can cause a noise ( rattle, squeak, grind ) under the conditions you noted. Not hard to adjust if there is an aftermarket adjuster at the fire wall or end of clutch cable at trans.
With a mirror on a stick and a flashlight you may be able to see the throw out bearing riding in the clutch fork. I suggest a decent set of jack stands placed under the control arms up front or on the k member. You'll have to get almost all the way under the car to attempt to see it.
There's a quick lube there near 17 that allowed me to pull my car over the quick lube pit to look at something under my car....and they didn't charge me. My driveshaft bolts were loose ( completely different scenario ).
Reactions: revhead347
FWIW, critics of the then-newly introduced Ford Top-Loader 4-speed claimed they emitted low pitched, growling noises that indicated coming disaster. Mine, one of the very first, Sep. 1964, 289 High Performance "K" package, did it. Not loud, but noticeable. Most evident in neutral. That trans got some real hard use, but never gave up. Ford claimed it originated in the synchronizer blocking rings. They used a much wider, stronger blocking insert than the old Borg-Warner design, like T-10.
How many miles and how severe the service has this T-5 seen? If it's pulled out for reason of checking other components, if no evidence is found for noise production, and based on usage, I would consider opening it's top, and measuring clearances between the blocking rings and gears. Wear is often severest on the 2nd. gear ring.
And then, of course, there was the Chrysler Products design using pin-type synchronizers: UGH!
imp
Don't know the history of the engine or trans before I got it three years ago. Checked the clutch adjuster and it is good. I only hear it when driving and accelerating. Nothing when slowing down.
I guess I will find out what it is when it breaks. Just hope it makes the 550 miles back home from mustang week. Maybe I will find someone down here to give me an opinion.
