T5 ?
  • Thread starter Thread starter shallto
  • Start date Start date Aug 7, 2005
shallto
464
OBX, NC
Aug 7, 2005
  • Aug 7, 2005
How much tranny fluid do I put in this thing? What kind?
dkins419
187
Michigan
Aug 7, 2005
  • Aug 7, 2005
You will need 3 quarts of ATF but it takes something like 2.7 quarts.
maverick0716
3,924
Chilliwack, BC, Canada
Aug 7, 2005
  • Aug 7, 2005
Yes, ATF and 2.7 quarts
shallto
464
OBX, NC
Aug 7, 2005
  • Aug 7, 2005
I was told by a mechanic to take out the upper drain plug and fill it till it starts to come out. Anyone ever hear that?
1EVIL88VERT
314
Dyess AFB, TX
Aug 7, 2005
  • Aug 7, 2005
i take the upper drain plug out and fill it through the shifter till it overflows, it's easier to fill that way.
shallto
464
OBX, NC
Aug 7, 2005
  • Aug 7, 2005
Thats what he told me to do, you just said it better. So is that the correct amount?
HISSIN50
34
129
Aug 7, 2005
  • Aug 7, 2005
As said, buy 3 quarts. you fill till it comes out the top hole - it should be close to the 2.6-2.7 quart spec. But watch for it coming out the hole, rather than fillling it per some spec.
good luck.
carbed87
215
  • Aug 7, 2005
yeah... i work at grease monkey, and thats what we do when we service any of our man. trannies. just take the check plug out, drain it, insert drain plug and add till it starts spewing out.
dont even bother pulling your shifter off, unless you want to add a bottle of tx7 or somthin like that
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 7, 2005
  • Aug 7, 2005
Be sure you have the car relatively level if you choose to use the 'fill it til it comes out the top hole' technique. But you can trust these guys - the capacity is 2.7 qts. -- so drain it; take the shifter out; replace the drain plug and put 2.7 qts. in through the shifter hole and you're good to go. Mercon/Dexron ATF - I use Amsoil synthetic.
CBZGT50
171
St Louis area
Aug 7, 2005
#10
  • Aug 7, 2005
  • #10
Where do you get amsoil synth and will it make shifting smoother? All I ever see is the cheap crap ATF. I think Lucas makes some synth ATF?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 7, 2005
#11
  • Aug 7, 2005
  • #11
Almost everybody who makes fluid makes a synthetic version. Amsoil has dealers everywhere - kind of like Amway. Do a google search under Amsoil and your city - see what comes up. But any synthetic Mercon/Dexron atf ought to work just fine. Hard to say if it will make yours shift smoother -- depends on the shape of the tranny and the shifter to some extent. Mine only has about 16K on it, and hasn't been abused at all. Shifts like butter.
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
