Ok my car was bucking on the highway only when I let off the throttle. In fact if I pushed in the clutch it would usually die out, so I had to restart the car on the highway by letting out the clutch in 4th. OK so I replaced my IAC, (w/ a new Ford one) and while I was at it I bought some B12 chemtool, pulled my intake plenum, and cleaned it out completely w/ the TB still attached. It was nasty black all in side. Put it all back together, and it idles flawlesslesy now. But it still bucks a little on the highway when I take my foot off the gas, and some at cruising speed - not near as bad as before, but when I push in the clutch it doesn't want to die at all, but also now the rpms drop to about 1,500, and then go up, and down 200-300rpms above, and below 1,500. Then after a few seconds will go to normal idle ~700rpm's. Any ideas ? What other sensors could cause this ? Seems to accelerate just fine w/ some decreased throttle response at very low rpms - Oh and no engine light
Considering all the waiting to install parts I have I do not need tuning issue right now
Thanks -
Thanks -
