RPM’s dropping off after steady speed
Greg Smith
27
After a sustained highway drive, if I simply kick the car out of gear and coast up an offramp, the RPMs fluctuate and drop very low until the car will die. If I run it down through the gears while going up the ramp, it’s fine. 2007GTCS, six speed trans.
The inside of the throttle body between the blades and the bores may have enough dirt deposits to restrict airflow when the throttle is closed. Remove the TB and clean it thoroughly.
Reactions: Greg Smith
