  • 1994 - 1995 Specific Tech
Tach jumping & Car Breaking Up
  • Thread starter Thread starter striansem
  • Start date Start date Jul 19, 2008
striansem
  • Jul 19, 2008
When I drive my car the tach jumps from 2k rpm to 3k rpm and breaks up and bucks during normal acceleration. It also does it even worst when under full accceleration. I have checked the fuel pressure, changed the fuel filter and looked for arking under the hood. I am very frustrated, does anyone have any ideas.
Thank You
desertcox05
379
south atlanta
Jul 19, 2008
  • Jul 19, 2008
pull your dizzy cap off and look for metal shavings in the bottom. if you do then the pip is going out and you'll have to replace it or and easier option would be to replace the distributor
striansem
  • Jul 20, 2008
Thanks, I will check that out. If I come up negative do you have any other suggestions?
desertcox05
379
south atlanta
Jul 20, 2008
  • Jul 20, 2008
it could be something as simple as a cap and rotor too. mine ran a lot better with a msd cap than a stock replacement
striansem
  • Jul 20, 2008
I put new cap, rotor and wires and car ran great. I did not see any metal shavings in the distributor.
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Jul 20, 2008
  • Jul 20, 2008
Sounds like what happened to me when the stator on my distributor went. Also might want to run some fuel injector cleaner through it and change the fuel filter. Just a thought.
striansem
  • Jul 20, 2008
Have a fresh tank of gas and just replaced the fuel filter, I will test the and get back to you. Thanks
striansem
  • Jul 21, 2008
Pulled of the harness off the coil and the contacts were a little corroded. Clean them up and checked the resistance on the primary and secondary on the coil and they were in specs. Test drove the car and the tach did not jump but car broke up but not as bad. Installed the stock fuel pressure regulator and car ran much better and intermittingly broke up at high rpm. I am think that I may have some bad gas and will put some dry gas and fuel injection cleaner in and see what results I get. The car does not break up under normal driving conditions anymore.
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Engine Misfire below 3K RPM
  • foxbodyclark
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
General karthief
