Tach needle stuck
djjazzydave
My 95 Cobra was in an accident last year (front end damage/bags blown), so over the winter I did considerable engine work (port/polish, 5-angle, replace valve train…).
Last night I fired up the car for the first time since doing the engine work and noticed my tach needle was on the wrong side of the rubber needle stop at zero RPM. When I start the car it rises from underneath the needle and acts like it’s trying to display RPMs but can’t make it past the rubber needle stop.
Folks on a couple of other forums said to tear out the cluster and move needle manually. Anyone seen this before and know how to fix it (without tearing out the cluster)?
Thanks,
D
Dave, welcome to the boards!
It seems to me that there are magnets in the tach which could have allowed this issue to occur. FWIW, it takes less than 5 mins to remove the cluster. Then another couple mins to remove the plastic facade and move the needle.
Good luck.
