  • SN95 4.6L Mustang Tech
Tach problems-no signal?
  • Thread starter Thread starter silver_02
  • Start date Start date Mar 29, 2004
silver_02
30
Bloomington, IL
Mar 29, 2004
  • Mar 29, 2004
I installed an Autometer sport comp silver tach in my car this weekend along with the MSD tach adapter for use with (coil on plug) DIS ignition systems. I tried to splice into the red wire going to one of the coils to pick up a rpm signal but all this gets me is about a 100-200 rpm reading on my tach-even when revving. Where am I supposed to take the red wire and the red/green wire to pick up a rpm signal?
00Perf RedStang
28
  • Mar 29, 2004
I recently installed a tach in my car, i was using the autometer tach adapter, i sure they work the same though. Here is the directions a guy from autometer gave me.
" Locate the large, square, 42 pin wire harness connector on the passenger side firewall. Look for pin #34, which is usually located towards the corner of the connector and is usually a solid red or red with a green stripe wire. Cut this wire in half and wire in the tach adapter in between the two cut halves. The solid red of the adapter will attach to the wire half that still has power when the key is on. The red with green stripe wire of the adapter will attach to the other half of the wire you just cut. This way the power to the coils flows through the adapter. Ground the black wire of the adapter and hook the gray wire to the green wire of the tachometer. "
Hope it helps, good luck.
silver_02
30
Bloomington, IL
Mar 29, 2004
  • Mar 29, 2004
Thanks for the info! I did exactly what you said and my tach works fine!
Slow5.0
2,554
Portland, OR
May 10, 2005
  • May 10, 2005
Sorry to bring old thread back
00Perf RedStang i read what you posted and looks right what i was thinkin, BUT i find this installation too http://www.ponyexpressperformance.com/tachinstall.html
So which one is right
BTW i tryin install tach with shift light in buddys 04 Mustang GT and he using AutoMeter adapter , please let me know because i have to installed today
Thanks
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
65 Mustang: Tried to install a tachometer from Oreilly's with no success.
  • spearce
  • Mar 26, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 19, 2026
spearce
P
Electrical MSD box wiring for an 88 GT- few questions.
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 25, 2024
pindude80
P
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
