yes they will fit....but I think you need to find an adatpter cause the 94 harness is different from the 96-98 harness....I could be wrong but I have read that you can hack up your harness to work with the newer lights if you wanted to.
It really doesn't require an adapter. One of the holes on each of the Vertical tallights is bigger than the socket from a '94-'95, so just lay the socket in the hole and you're good to go.
