what do you guys think of taking out the supercharger and putting in a big turbo?? what will the performance be like? will i gain or lose performance? or how about leaving the supercharger in and adding a turbo if thats possible?
SWortham said:You could benefit either way. A turbo has its pros & cons. Turbo lag is the biggest con. But lots of potential for lots of horsepower is the best part.
The Eaton supercharger you have on there is a roots-type supercharger which provides a good boost at the low-end while a turbo would not.
And you could leave the supercharger and add a turbo. That way, you'd still have that low-end boost that the supercharger provides as well as the monster power potential you can get from a turbo. But with more power, comes more risk. Make sure that the engine is going to be able to handle the extra power. And you need to find a shop with a lot of experience with these kinds of upgrades. It can be done, and it can work great, but it's expensive and it's risky.
You might be better off with just upgrading your supercharger with a good Whipple supercharger (twin-screw). I think that's what the Kenne Bell kit comes with.
mers1083 said:what do you guys think of taking out the supercharger and putting in a big turbo?? what will the performance be like? will i gain or lose performance? or how about leaving the supercharger in and adding a turbo if thats possible?![]()
SWortham said:The twin-turbo route is not really optimal either. With a twin-turbo setup, there is more pressure loss compared to a larger single-turbo setup. And even when you're using two small turbo's, you still don't get boost until around 2,500 or 3,000 rpm's. And the supercharger boosts from idle & up.
If you're going to add a turbo, you might as well leave your supercharger on there. They don't interfere with eachother. It's been done before, and it's a good way to make some serious power.
