D.Hearne
I think he's also got the firing order wrong. If you've wired it 15426378, then try 13726548. Pertronix could be damaged, the Pertronix I I had would pop and sputter after a backfire thru the carb. Had to shut it off and restart it to clear it up most times. Check also the valve lash, too tight a setting here will also cause rough running. Pull the plugs and examine them one by one. I had a rough running 400 that turned out to have a closed spark plug gap, from the heads getting bumped around while the motor was disassembled.
