You do not need the fuel line disconnect tool...when you unbolt it from the lower intake (4 bolts) it should swing out of the way...part of the fuel rail was bolted to my head bolted so I removed it and it swung way out of the way so I could install the lower...
The disconnect tools are like $10 bucks for the set at your local parts store but you don't need them...just swing them out of the way when you unbolt everything...hold it up somewhere with tape or bungy cords or whatever you want...
The injectors will pull out (you might need the O-rings for the injectors) because they will most likely come out in pieces or no long serve their purpose (to stop leaks)...oh and to pull the injectors out of the rail and intake just twist them as you pull up evenly and they should "pop" out...with no problems...
Do a search for Jricker...he has a post that has the part #'s for the rubber O-rings...your local parts store might have them if you ask them...and you won't need those part #'s...
Good Luck
