taking stripes off
  • Thread starter Thread starter 87WhiteStang1
  • Start date Start date Jun 10, 2009
87WhiteStang1
182
  • Jun 10, 2009
So i would liek to take the red stripes off the molding on my white GT... it appears that all of it is just sticker. any tips for doing this. I was planning on using a heat gun. pointers would be great i dont want to f*** it up. Thanks
rbonella
409
@ home
Jun 10, 2009
  • Jun 10, 2009
I have never removed GT stripes before, but use a heat gun on LOW, and you will need some adhesive remover for the left overs. It will probably be a little tedious due to the age of the stickers and once you start...you're comitted! I had a friend try to remove his red stripes off his black 88GT, he became fed-up really quick and decided to use electrical tape to cover the red. That lasted for about two days and looked crappy needless to say. Take your time, and do it right. Good idea to wax your moldings after you use adhesive remover though. Good Luck!
Turd Tops
103
South Lyon , Michigan
Jun 10, 2009
  • Jun 10, 2009
I had an 87 Turbo Coupe with the same red strip on the molding. I did'nt remove it but covered it up with real wide silver pin-stripe. I'm sure you can do the same with a very wide black pin-stripe. My friend with the same car just used plain old black tape and worked very well for him.
N
NotchAbove
29
  • Jun 10, 2009
They do make exact fit stickers, I would check CJ Pony Parts or LRS. I would think they may have white, I will see if I can find them for you.
EDIT: For the price this sounds good to me.
http://www.latemodelrestoration.com/products/1987-93-Mustang-Body-Stripes
Cobra912
1,777
11
39
Wish I was anywhere but here
Jun 10, 2009
  • Jun 10, 2009
use patience grasshopper, patience
justagt
143
  • Jun 10, 2009
Time
It can be done, I did it on my other black LX that had a red stripe in the molding.
I did not use a heat gun, but I did it on a 85 deg day. It takes time, a razor blade helps to just grab the corner of the stripe sometimes. Googone may help too. The problem is the stripe will break apart as you try to remove it so you will end up having a lof of little 1 or 2" pieces you need to try to grab onto and remove.
Took me the better part of a day to get it all removed and get the residue off.
Looked tons better with the stripe gone.
87WhiteStang1
182
  • Jun 10, 2009
Mustang 1987-93 Body Stripes at LRS - Same Day Shipping!
thanks man... i think il try to remove them when i got a day when i know i have time... if that doesn't work too well i guess il be ordering those bad boys... thanks for the info guys!
1987stangman
684
24
  • Jun 11, 2009
Another trick I used couple times is a hobby iron. Since I'm in to R/C planes I decided to try using one that I had that is used to shrink/remove monokote film on model aircraft. It works good because they are flat irons and you have more control over the heat and can use "socks" so that you dont transfer anything to the mouldings like dirt or color, avalible any where the irons are sold. Like everyone else said though, you need a few hours and some patience.
Paint and Body Stripe kit for the Foxbody
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
gkomo
W
Strange connector near fuse box
  • W4rl0ck
  • Sep 23, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 28, 2026
gkomo
M
Kind of a unique problem
  • MadMatt7
  • Oct 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2026
rednotch
G
New member 1991 GT Convertible with 31k original miles
  • gvanginkel403
  • Oct 30, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 30, 2025
gvanginkel403
G
M
How To Decode
  • Malcoll1
  • Mar 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
FoxChasis
F
