Taurus/contour E Fan Vs. Flex-a-lite Extreme Puller Fan. Which One Pulls Most Cfm?
  • Thread starter Thread starter larrym1961
  • Start date Start date Sep 15, 2012
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Sep 15, 2012
  • Sep 15, 2012
An earlier post I asked what water pump was best for cooling. Now I would like some opinions on if a Taurus or Contour duel E Fans would outcool a Flex-A-Lite Extreme cooler fan?
aar0s
1,015
55
69
Sep 16, 2012
  • Sep 16, 2012
I would think that as long as a shroud and the lower air dam is in place either one of those would work fine. Ive never heard anyone having a problem with the Taurus/contour/mark VIII fan setups though. There's a write up on how to get one to fit in a stock shroud around here somewhere...
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Sep 16, 2012
  • Sep 16, 2012
The flex-a-lite pulls 3300cfm if I remember correctly. I'm also relatively sure that the Contour, 3.8 Taurus, and Mark VIII pull 3600, 4000, and 4500 respectively. All of which will cost a fraction of the Flex-a-lite. Those 3 fans are used by people everywhere from Mustangs to even Jeeps and Corvettes.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Sep 16, 2012
  • Sep 16, 2012
What scott said
I have a Mark 8 fan and it works very well
Reactions: Toneyb35
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Sep 16, 2012
  • Sep 16, 2012
That is what I read also for the Flex-a-Lite. I am currently using the Extreme Puller but am entertaining the thought of using the Taurus/Contour fan. You can even get one of those from Rock Auto new for less than $100
Toneyb35
47
New Orleans, LA
Sep 17, 2012
  • Sep 17, 2012
GroverDill said:
What year Mark VIII fits an 87GT???
Wisenthefools
  • Sep 19, 2012
I believe they're all Identical in size/fitment. No particular year will just fit right in but it's an easy job. You really just have to test fit, measure and then cut the shroud to clear the water pump/crank pulley. It won't fit the diameter of the radiator perfectly but it's still a nice fit for most Fox radiators...
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Sep 19, 2012
  • Sep 19, 2012
Personally i've been using a Mark 8 fan for years now, and i believe it's the only reason i've gotten away with running a 347 on a stock '89 radiator and never had any cooling issues. It's simply a beast of a fan. I remember reading years ago that the only other fan of this size that you can buy that puts out more CFM was a Dodge Viper fan, and good luck finding one of those cheap (or at all).
That said, i am working on a Contour setup to see how i like it, but if it doesn't keep my car as cool then the Mark will go back in.
Reactions: 95Vert383AOD
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 20, 2012
  • Sep 20, 2012
Go with either fan and either a DCC or FAL controller and you will be much happier than the FAL fan. They flow better and you can pick them up in a junkyard for less than $50. Add in the VSC for $100 and the other small parts needed and you will come out about $200 ahead of the game. I just scored a Taurus fan for $20 from Upull it. There are several good write ups on the install here and on the Corral.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Sep 21, 2012
#10
  • Sep 21, 2012
  • #10
How are you guys running the E-fans? On a switch in the dash? Just bought another fox and in the pics, it's got an E-fan, which looks to be aftermarket. I haven't got the car here yet, but just curious. I hope the thing works. lol
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Sep 21, 2012
#11
  • Sep 21, 2012
  • #11
If a Mark III fan is not available from a salvage yard, RockAuto has the fan and motor sold seperately. $218.58 for the both. Yes that is fairly pricy but if you price a Flex-A-Lite Extreme Puller fan like the one I have those are well over $300. Not bad for the Mark III considering it pulls 4000 CFMs compared to the Extereme Pullers 3300 CFMs.
As for a controller for mine, I am using a Flex-A-Lite Veriable Controller.
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 21, 2012
#12
  • Sep 21, 2012
  • #12
Get a Mark viii fan on ebay even...Trim the tabs and stuff. I cant remember off hand but i believe there is a 40-45 amp draw when it kicks on. So if your alternator is under 100 amps it is strongly recommended that you upgrade.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Sep 21, 2012
#13
  • Sep 21, 2012
  • #13
I've read it's more like 4500cfm when on high.
As for a controller, i use one of those old school copper coolant hose probes. It slips in under the top tube and into the radiator and has a coiled copper line that connects to an adjustable dial. It was $30 at the local speed shop 10 years ago when i got my coupe. It works fine enough for me
Oh, and don't waste your time with a Mark fan if you don't have at least a 3g alt. When that SOB kicks on your car will probably stall if you're still running a stocker.
RacEoHolic330
4,014
1,698
203
Allentown, PA
Sep 21, 2012
#14
  • Sep 21, 2012
  • #14
It's actually about 70 amps. Most people that don't have controllers use a 75 or 80 amp relay and a switch to turn them on and off manually. A PWM controller would definitely be the best option though.
SVT32VDOHC
3,501
28
119
Motor City
Sep 21, 2012
#15
  • Sep 21, 2012
  • #15
Got my car in...fan looks like a POS...have yet to see it turn on too. I found a stock fan and clutch + shroud, so that is going on there, no matter what!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Sep 21, 2012
#16
  • Sep 21, 2012
  • #16
I seem to recall 90 amp spikes on startup, but i'm running an 80 amp relay with no issues.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 21, 2012
#17
  • Sep 21, 2012
  • #17
You need to get a VSC to avoid the spike/surge in amps upon startup. The VSC have soft startups built in.
Either get this VSC (be prepared to wait several weeks)
http://www.dccontrol.com/selector.htm
Or if you can't wait get the FAL 33054 from Summit for $100
Here's a great writeup on how the install of a Taurus fan with the FAL VSC
http://forums.corral.net/forums/articles/898470-installing-taurus-fan-vsc-5-0-a.html
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Sep 21, 2012
#18
  • Sep 21, 2012
  • #18
With my 130 AMP 3G alt. when my Extreme Puller kicks in the AMP needle does not drop. Even with UD pullies.
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
Taurus Fan And Fal 33054 Install On A Fox
  • No.11
  • Oct 4, 2016
5K
Fox 5.0 Mustang Tech Oct 11, 2016
MFE92
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
T
Fox No Boost And Stumped
  • TWEECD
  • Aug 12, 2017
  • 2 3 4
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2017
TWEECD
T
Fan Options For '65 289 With Factory Radiator, No A/c
  • csxfbird
  • Jul 24, 2015
1965 - 1973 Classic Mustangs -General/Talk- Jul 24, 2015
csxfbird
