taurus wiring question...
jmd2914
937
Napa, California
alright, just got back from the junkyard and got my taurus fan and wiring harness. i think its out of a sable though. anyway. how can i test this fan before i put it in the car? and anyone have a wiring diagram? the simpler the better, i suck and electronics. im just wiring it to a relay and a switch. thanks.
Joel
If it's two speeds, the outside terminals are likely the ground and high speed. I'd put a FUSED 12 volt wire from the battery on one terminal and ground the other (this is how you test fans at the J/Y). If the fan spins, cool. If it spins the wrong way (pushing air), swap the wires. You really cant screw it up (unless you short a couple terminals together).
Good luck.
jmd2914 said:
ok cool, anyone happen to have a wiring diagram for wiring the fan to an on/off switch with a relay and no a/c
Here's one article. If you dont want to use a controller, omit it and wire the relay directly (I'd recommend that your switch sends ground to the [control side of] the relay).
Good luck.
jmd2914 said:
one more question, do i have to run the diode from the posetive to ground wires on the fan motor?
It's a good idea. When a fan is shut off, it continues to spin. And while doing so, it goes from being a fan to a generator, and in this latter stage it can create a rather large voltage spike. The diode kills the spike before it goes back to your relay (the spike can shorten the life of the relay).
Good luck.
