  • SN95 4.6L Mustang Tech
TB or Pulleys
  • Thread starter Thread starter Mikestang01
  • Start date Start date Jun 8, 2005
M
Mikestang01
  • Jun 8, 2005
i was just curious what to do next a 70mm TB or set of UD pullys
i have a coldair kit and xpipe and muffs and a programmer so the TB would see some benifit right?
and pullys free up a few ponys i heard .
just kinda curious as to which would be the better gain
02GTKB
122
  • Jun 8, 2005
You will get more gain with the UDP's, you wont get much gain going from 65mm to 70mm while you are NA
Superhereaux
chicks make me feel inadequate
538
South Texas
Jun 8, 2005
  • Jun 8, 2005
a tb alone isn't worth it. you'd need a decent air intake and a plenum to see any decent gains
M
Mikestang01
  • Jun 8, 2005
I Gotcha so UDp it is , one more thing the Steeda's worth the price increase over the BBK's? or is it the name thing you paying for?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 8, 2005
  • Jun 8, 2005
neither
02GTKB
122
  • Jun 8, 2005
He asked what to do next and if which would give more gain!! he didnt asked about CAI or Plenums
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Jun 8, 2005
  • Jun 8, 2005
I would also go with UDP pullies first (I recommend Steeda) and then save up for a nice TB and plenum combo later!
J
Jakes
84
  • Jun 8, 2005
I hate to see people get misinformed so some one who knows what they're talking jump in here.
It used to be changing the pulleys would help pick up a number of ponies by turning things slower (ok, if you're not caught in rush hour stop-n-go). But, Ford changed the pulleys, I think starting with the 2000 models, turning things slower right out of the factory. There's just not that much to be gained as there used to be.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Jun 8, 2005
  • Jun 8, 2005
save the money, neither are worth it. get some gears, shifter or something that is going to make a difference.
Mirrahasmycar
210
CT
Jun 8, 2005
#10
  • Jun 8, 2005
  • #10
Don't waste your time with the BBK pullies, they are garbage, Go with the Steeda pullies with the SFI balancer, they should free up more than just the TB, the TB will give you about 1 hp by itself, but the CAI, TB and Plenumn will make it worthwhile
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 8, 2005
#11
  • Jun 8, 2005
  • #11
Pullies represent a great risk to your engine in multiple ways. Just say NO to pullies... Not worth it.
02GTKB
122
#12
  • Jun 8, 2005
  • #12
C
chimchim
267
PA
Jun 8, 2005
#13
  • Jun 8, 2005
  • #13
What about the Steeda's on a 97?
csledd
1,115
Paducah, KY
Jun 8, 2005
#14
  • Jun 8, 2005
  • #14
Please explain sir?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 8, 2005
#15
  • Jun 8, 2005
  • #15
Things to consider
* The vehicle is engineered to work from the AZ desert to sub zero temps in the northern states. Perhaps you are able to slow your water pump and alternator down with out a problem. Just remember that the entire cooling system was engineered on how much heat your engine makes, how much HP it produces.
* If you start adding power modifiers AND under drive the accessories, this may be a recipe for problems later.
* If you find your self mainly making a lot of short trips and idling for extended a period of time, then under driving your alternator may be a problem later also.
TSB 14520
4.6L 4V Pulley Instructions
Some 1996-2001 Mustang owners, for engine performance purposes, are adding a special front drive pulley kit to reduce front accessory drive speeds. When removing and replacing the crank pulley, if the large bolt used to hold the crank pulley undertorqued, the keyway will shear and cause major engine damage. The resulting engine damage is not warrantable. If the crankshaft pulley bolt is removed it should be replaced as it is a torque to yield bolt. The installation of the crankshaft pulley requires that a specific torque operation be adhered to. The crankshaft pulley bolt must be installed using these 4 steps: 1) Torque to 75 lbs/ft 2) Back out one turn 3) torque to 45 lb?ft 4) continue to tighten and additional 90 degrees.
csledd
1,115
Paducah, KY
Jun 8, 2005
#16
  • Jun 8, 2005
  • #16
4v pulley.. so that only effected mach 1's and cobras?
what would one consider a "short trip"
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 8, 2005
#17
  • Jun 8, 2005
  • #17
Yes it says 4V BUT installing pullies is not all that simple and the crank pulley has special torqueing procedure for any model. Plus the modular engines do not benefit that much from the mod. I would never put pullies on my car is all I am saying. I do not recommend it...
J
Joel's98GT
368
central OH
Jun 9, 2005
#18
  • Jun 9, 2005
  • #18
"The crankshaft pulley bolt must be installed using these 4 steps: 1) Torque to 75 lbs/ft 2) Back out one turn 3) torque to 45 lb?ft 4) continue to tighten and additional 90 degrees. "
Yeah, WOW this would be a tricky procedure, IF you were someone who has never been introduced to a wrench before!!!!!!!
Kilgore Trout said:
Having a vagina will cause you to be afraid of multiple things without the ability to reason. Just say NO to SQUATTING TO PEE!!! not worth the headache you give others.
FIXED! You don't mod your car, you aren't a mechanic, you have no real world expierience to back what you say up. Buy a civic already!!!
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
