TDC mark jumping around
  • Thread starter Thread starter timetrialman59
  • Start date Start date Apr 5, 2010
T
timetrialman59
  • Apr 5, 2010
Hey guys new to this forum but have a problem. I have a 5.0HO engine that when I reset the TDC, removed bad dizzy, I get the timing mark "jumping" around when timing light is used, 15 BTDC is what I need. When I disconnect the spout I can set it OK and runs great but when I connect back for computer control, has a A9L with fresh tune SCT chip, it will not start, remember the jumping mark. Did I index the dizzy wrong? Retarded or advanced it 1 tooth off? Need some help here, thanks.
ps The engine is custom Jasper Racing with a Vortech 50lbs. injectors, all custom parts inside going thru a Zoom clutch to a T-56 race trans, to a 8.8 rear Posi all inside a Volvo 744. youtube has it "V-8 Volvo spanking a Porsche"
pps thanks for your help! timetrialman59
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Apr 5, 2010
  • Apr 5, 2010
Thats normal. And its not really the TDC mark jumping, its the timing of the spark as its detected by the timing light.
With the SPOUT in the ECM uses spark as an Idle control function. So it will jump around. Dont sweat it.
That being said, you set the timing with the SPOUT plug out, and let the ECM do its thing when the SPOUT is installed.
Tanus
847
A to the Z
Apr 5, 2010
  • Apr 5, 2010
post pics if you got them, I gotta see this thng
like said above, set to 12-15 with spout out, timming light show be super steady with it disconnected.
T
timetrialman59
  • Apr 10, 2010
Thanks it's fixed! Will post pics. soon!
Install '87-'95 Heads, Cam, Intake Install
  • 5spd GT
  • Sep 25, 2013
  • Resource Discussion Forum
12K
Resource Discussion Forum Sep 26, 2013
Gearbanger 101
Car won't start after being garaged
  • bmo37
  • Jul 27, 2008
Fox 5.0 Mustang Tech Jul 28, 2008
jrichker
Roush Jack Roush Jr - Grand Am Racing Blog
  • timeless2
  • Aug 26, 2009
  • Special Production
2K
Special Production Aug 26, 2009
timeless2
Timing is at 19* / Jumps around to +40* !
  • ozanracing
  • Jan 25, 2007
Fox 5.0 Mustang Tech Jan 26, 2007
jrichker
ON 302 vs. 5.0L H.O. DISTRIBUTORS
  • joeythesaint
  • Sep 25, 2006
9K
Fox 5.0 Mustang Tech Sep 25, 2006
joeythesaint
