- Jul 18, 2005
- 71
- 0
- 0
technical maf/injector question/theory
Alright so heres what i know, im running 344 horse 360 torque on my 89 5.0.. Now according to the math for fuel injectors im running at over 90% duty cycle on my 19lb injectors which isnt exactly ideal.. Now my maf which is after market 75mm i believe,calibrated for 19lb.. I got ahold of a set of 24's which would be a bit better for my application, but heres where i lose my understanding.. If im not mistaken a stock maf is 55mm.. now when i installed my 75mm maf i then changed the velocity in which the air flows over the hot wire, the less velocity of air passing over the hot wire changes the voltage needed to maintain the correct temprature of the hotwire which would send a different signal to the pcm for load calculations and fuel delivery correct? and that bring me to the injectors, even if i installed 24lb injectors with a maf calibrated for 19lb, wouldnt they oxygen sensors adjust duty cycle on the injectors to get the correct air fuel ratio? providing that fuel trim isnt maxed that is..I know iv read everywhere that maf and inj need to be calibrated but i kinda wanted to dig a little deeper..
