Technical Thread / How To's
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
428
154
Boca Raton, Florida
Here you go everyone, a Technical/How-to thread index! For FOX Body and SN95's with Ford Fuel Injection 86- 95.
This is to replace the current "Official HOW TO THREAD" with an easy to navigate index of threads and write-ups on some common tasks related to our cars. I stole this idea from Daggar, so I can't take credit for it, but this should be very useful to all the members, new and old. If you come across something that you feel should be added, please shoot a PM to the moderators of this forum to have it added to the list!
87-95 Heads, Cam, Intake Install Help - 5spd GT
94-95 Mustang Serpentine Belt Routing - Bullitt95
Cranks OK, but No Start Checklist for Fuel Injected Mustangs - jrichker
Common clutch part numbers and clutch installation write-up - 5spd GT
Cylinder Head Removal & Replacement - jrichker/5spdGT
EEC-IV Trouble codes - quick reference .pdf - StangGT1995
HOW TO: 13" BAER REAR ROTOR UPGRADE - 91LX_5L
How to check piston to valve clearance
How to install headlights and foglights - davis3
How To Install Radiator W/Mishimoto Brackets ****PICS**** - davis3
How to install manual fan switches - CManT1914
How To Install-Sequential Tail Light Kit ***pics*** - davis3
How to install pedestal mount rocker arms
How To Install-Poly Axle Housing Bushings ***Pics*** - davis3
How to paint your dashboard - davis3
How to remove and reinstall your timing cover - Danman765432
How to replace fuel filler tube gasket - davis3
In-tank fuel pump replacement - 5spd GT
Need Seafoam 101: How to use - 94-302-vert/Chythar
Pictorial Guide to Odometer Gear Replacement - Jinx102672
How To Delete The A/C System ***PICS*** - davis3
Surging Idle Checklist - jrichker
