ive been debating about what im going to do...
i dont know a whole lot about the teksid block... i get that its about 70 lbs lighter because its aluminum, and apparently it can hold about 1000 rwhp.
now...
im looking at options to go with a forged bottom end. i am mechanically inclined enough to build a short block myself. i have a kenne bell, and i want to run 15+ psi (and eventually spray it).
this leaves me a couple of options. i was originally going to go with a forged stroker frpp boss block from MMR, low compression pistons, and top it off with the 44cc twisted wedge heads w/ PD Supercharger cams specifically for trickflow heads.
however, i just noticed there are 2 teksid's for sale on craigslist in my area... one is from a 98 cobra and comes with the forged cobra crank for 500. the other is a long block from a mark VIII for 300.
does the mark VIII motor have a forged crank like the cobra?
the cobra motor had a bad rod bearing, so i know that either way the cookie crumbles, im looking at machine work... so how much can the teksid block be bored out? i am guessing that because its aluminum, its sleeved... can that be machined, or would it need to be re-sleeved?
i am assuming that if i bought the cobra motor and the crank is salvageable, and if i put a nice set of forged h-beam rods and forged pistons w/ clevite bearings i would be in it around 2500 w/ machine shop... it should be good for at least 1000 rwhp... am i right?
Also, im thinking that a KB 2.1 spinning 15+ psi (small sc pulley & larger crank pulley) on a forged 4.6l w/ trickflow heads and cams should net me between 550 & 600 rwhp. does that sound correct? or am i completely off?
Sorry for the long post, and please dont rip me up if im completely off, im just trying to get my stuff in line before i go dropping cash.
Thanks!
now...
Thanks!
