Help me troubleshoot the temp gauge, it stopped working recently. I checked all the connections behind the gauge bezel and everything was intact...maybe I need to replace the sensor on the intake manifold? Could that be it
Remove the wire from the temp sensor and ground it to the motor with a good connection. Turn the key to the "on" position--did the gauge max out now? If so you have a bad temp sensor.
