temp gauge off the wall
zeusmoto
390
utah
k guys i heard that factory gauges sucked, and my temp gauge has always worked fairly close to the actual temp. today i would be waiting at a light, and my gauge would go up pointing straight up, it hardly ever reaches between the "normal" marks just because it never really heated up. but today it almost went past the normal marks into the too hot area... then when i would start driving it would drop some... what is up.. please help
hey Zeus,
you said it, the stocker sucks (though im not familiar with the pre 87 gauges) - i dont imagine they got worse with newer models.
get a real gauge so you know what is really happening. the thermostat really determines what is going on with the cooling system - if your gauge read cold normally (after driving for awhile), unless the stat was stuck, the system was at or around the stat temp, and your gauge was a little slow/low.
good luck.
i have an autometer temp gauge occupying one housin on my pillar... it is not set up... it came with the car i dont know if its mechanical electrical...or whatever. i dont know what hardware i need or what i need to set it up... please help... this gauge hasnt done this before.. i also have no t-stat so my car took a while to heat up to normal... but now it heats to fast or something :( my car is sick:(:( i hope im not the only one who thinks of my car as a person
no im sure you are not the only one to consider your ride a person.
if the aftermarket gauge has a long capillary tube attached to it, it is mechanical. i doubt this, so it must be electrical. i might try and get my hands on a sender (the vendor can help with this). then wire it. one pos and neg for lighting and power, and one wire for the sender. cake.
are you sure your fan is kicking on (and at the right temp, whatever you set it at)?
good luck.
i have no idea on how to check the fan turn on temp... also i want to make my boost gauge light up but i dont know how.. and my tach.. it lights up but stays lit all the time couldnt i wire it to the headlight switch or something...? any ideas i also heard you can change the colors of the bulbs is this true and if so where at?
JB, if you have a 180 stat, i would find it hard to believe you actually run 130 sustained. the stat really regulates the temps - if below 180, the stat closes, so it does not matter how good the radiator is. do you have a real gauge, and where is the sender for it?
zeus, try to find the ISO circuit. on 87+ stangs, there is a dedicated fuse for it. not sure on your 86. also, there might be one wire for the dimmer circuit on the back of the headlight switch. pull the switch and put the probe of a test light on each wire (ground other lead). then turn on lights and as you probe each wire, move the dimmer (you have a dimmer, right? i dont know). when you find the wire that allows the test light to dim when the dimmer is turned, you have the right one. use this to power your gauge lights.
alternatively, if no dimmer, just find the parking light feed (under dash - look at schematics - on my 88 it is a brown wire), or use one of the wires on the back of the switch that is hot only when the parking lights (and headlights) are on. use it and your gauge lights will come on with the other lighting.
i think autometer sells different color bulbs, or covers for the bulbs. im not sure on that.
good luck.
alright thank you so much hissin to the rescue haha.. but anyways do i just run a wire off of the two wires to the dimmer wire or do i need a special connection? please help... thank you in advance
Zeus, is there an ISO fuse (iso is what it is called on the 87+ cars). basically a dimmer fuse. if so, tap off the dead side of that fuse. you can buy special fuse taps at the parts store. it is a thin metal connector that piggybacks the fuse's blade. then you can connect a wire to the thin metal piggyback deal.
if no fuse, find the correct wire off the headlight switch, etc. you can bare some insulation and splice in a wire, which will run to your gauge(s). or you can use a plastic tap - also at the parts store. if used correctly, they work very well, IMHO.
all you are doing is putting a Tee on the existing wiring, so do what makes sense to you (no special connectors, per se, needed. just use common sense). also, i would put a 1 amp fuse on the new wire you run. that way, should the wire develop a short, you will just blow that little fuse, rather than taking out a larger circuit, all the parking lights, frying the dimmer, or catching the wire on fire. :) just a nice thing to do. very easy too.
good luck.
