Temp gauge
  • Thread starter Thread starter kfellers
  • Start date Start date Sep 15, 2005
kfellers
66
  • Sep 15, 2005
Okay guys, my stock temp gauge quit working tonight, what could be the problem and where do I start looking to fix it?
J
Jeff7477
176
Lincoln, Nebraska USA
Sep 15, 2005
  • Sep 15, 2005
Temp sensor in intake manifold.
bubba-dough
1,044
Indiana
Sep 15, 2005
  • Sep 15, 2005
The temp sending unit in the lower intake on the drivers side.
HISSIN50
34
129
Sep 15, 2005
  • Sep 15, 2005
Or just install a real gauge and know what is going on.
The stock sender is 4 bucks at the local parts store (not sure how much a Motorcraft sender is, but with how the gauges are calibrated, I dont see the need for a 'precise' sender).
Make sure the sender wire is not pinched or chafed (a DMM set to ohms can help determine this). Easiest to throw 4 bucks at it with a new sender first.
Good luck.
iskwezm
4,159
20
79
Rowland Heights,California
Sep 16, 2005
  • Sep 16, 2005
take the sender signal wire and ground it,this will max the guage past hot to let you know if the guage still works.If it doesnt move,either wire problem or bad guage.
kfellers
66
  • Sep 21, 2005
$8 temp sensor, a 17mm socket and 5 minutes...good as new! Thanks guys!
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 21, 2005
  • Sep 21, 2005
Take above advice..if your worried about a gauge working, make sure it's a REAL gauge, stocker is not up to snuff.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
