Temperature Question
  • Thread starter Thread starter USCGunner
  • Start date Start date Aug 4, 2017
USCGunner
60
12
28
Idaho
Aug 4, 2017
  • Aug 4, 2017
My 91 Lx 5.0 constantly runs at around 160 deg no matter what the outside temp is. Is this correct or do I need to think about a new thermostat?
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Aug 4, 2017
  • Aug 4, 2017
Someone mat have installed a 160 degree thermostat in it. The stock thermostat is about 192 degrees. You can disconnect the wire at the coolant temperature sensor and ground the single wire to the block to check the gauge operation.
On an EFI car the temp is important. 160 degrees won't allow the computer to go in closed loop....meaning it would run in warm up strategy all the time.
I'd advise at least a 180 degree T stat.
Reactions: imp
imp
Mustang Master
Jul 13, 2017
531
107
83
Aug 5, 2017
  • Aug 5, 2017
In summertime, especially in hot locations, the stat opening temp. is largely immaterial: the engine will operate at 200` or higher, no matter what stat is there. Where I reside, for example, thermostats are always wide open, 8 months of the year, regardless of their opening temp. So, under such conditions, the "closed-loop" problem becomes a moot point.
Still, I've always tried to picture the scenario in, say, Fargo, driving with a 160 in winter, would my EFI ever achieve "closed-loop"? Imponderable question. imp
Real time recon
Mustang Master
Aug 21, 2016
469
205
83
Aug 5, 2017
  • Aug 5, 2017
My 90 GT 302/345 EFI (with 180* stat) runs at 180* +- 5* ALL the time after warm up.Doesn't matter what the air temp is.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 5, 2017
  • Aug 5, 2017
EIther the thermostat is not installed or it is stuck open
Reactions: imp
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Aug 5, 2017
  • Aug 5, 2017
I would never run a t-stat below 180*. If you can't cool your car then you need a better radiator and/or fan setup. If the fan kicks on shortly after the t-stat opens, the coolant temp should immediately start to lower. If it doesn't you have a problem and it's not your t-stat.
Reactions: 90sickfox and a91what
Sparky714
5 Year Member
Oct 16, 2015
382
213
73
North Dakota
Aug 5, 2017
  • Aug 5, 2017
Being a North Dakota resident, I can safely say that you would have more to worry about driving a short wheelbase rear wheel drive Mustang on a slippery road in the winter in ND than if your ecu was going in to closed loop. Just sayin. And no, it would probably never get warm enough.
Reactions: imp
imp
Mustang Master
Jul 13, 2017
531
107
83
Aug 6, 2017
  • Aug 6, 2017
@Sparky714
Love your reply!! Wife & I flew to several places up there from PHX, seeking retirement possibilities. Billings, then Bismarck. Decided no. Lovely places in MT, went to Roundup, looked at a self-sufficiency set up in a canyon, water running constantly down from above. Guy lived there with his wife & kids, way, way, off the grid. We had done it before, so passed.
Again, love your reply! Thanks! imp
Reactions: Sparky714
Redfire Fox
56
26
39
Aug 6, 2017
  • Aug 6, 2017
I wouldn't go lower than a 192/195 stat. The car runs most efficient at that temp. Most engine wear occurs when the engine is cold.
Reactions: imp
USCGunner
60
12
28
Idaho
Aug 11, 2017
#10
  • Aug 11, 2017
  • #10
Ok sorry to bring this back up but this car confuses the heck out of me. I have been driving this car for about two months now, like I said 160 deg is where it always set. Today outside temp 97 deg and the thermostat started reading 190 deg, why all of the sudden.
deathb4dismount
Crap, didn’t realize my crotch was in that picture
1,031
502
164
THE BUCKET
Aug 12, 2017
#11
  • Aug 12, 2017
  • #11
do you have an after market gauge or are you just going by the reading on the dash?
USCGunner
60
12
28
Idaho
Aug 12, 2017
#12
  • Aug 12, 2017
  • #12
Just the dash
91 LX 5.0 getting hot when a/c is running
  • 91lx14gt5.0s
  • Jun 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 4, 2026
manicmechanic007
Z
Gauge cluster swap
  • Zeke1995
  • Jul 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 16, 2025
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
