  • SN95 4.6L Mustang Tech
Tensioner bolt torque spec?
  • Thread starter Thread starter OneStiffGT
  • Start date Start date May 5, 2007
O
OneStiffGT
87
Canada
May 5, 2007
  • May 5, 2007
What is the torque spec for the belt tensioner bolt? I tried to do a search or two, after looking through 15 pages of results I couldn't find it.
Thanks
5.0's 4 ever
The #1 Stunna
5,794
Orlando, FL
May 5, 2007
  • May 5, 2007
Ford has it listed as a two step process:
1. Tighten to 10 Nm (89 lb-in)
2. Tighten an additional 90 degrees
I would guess its around 15ft .lbs, pretty much just don't try to tighten it too much or it will break due to the front cover being powder cast aluminum.
Tensioner arm bolt
  • brandon4v
  • Jan 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
