Tensioner release?
  • Thread starter Thread starter sgw_88FoxGT
  • Start date Start date Jul 30, 2008
sgw_88FoxGT
43
  • Jul 30, 2008
I need to replace my tensioner pulley but I can't figure out how to release the tensioner arm. I assume I have to release the spring pressure in the arm before I take off the pulley, but how do I do it?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 30, 2008
  • Jul 30, 2008
Remove the belt, then remove the bolt that holds the pulley on the tensioner arm. Caution!!! The bolt through the center of the pulley has a LH thread. Turn it clockwise to loosen it. I stripped the thread in mine trying to replace the pulley because I didn't know that it was a LH thread. I ended up spending $73 at NAPA for a new tensioner assembly.
sgw_88FoxGT
43
  • Jul 30, 2008
I know this is an elementary question but, how do I remove the belt? I've never done it before so I don't want to damage it.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 30, 2008
  • Jul 30, 2008
Use an 18 MM socket on a extra long breaker bar or ratchet on the pulley mount bolt. When you pull counter clockwise on the breaker bar, it release tension on the belt.
sgw_88FoxGT
43
  • Jul 30, 2008
Thanks for the help.
How does jrichker know everything?
4G-KDMP
935
CA
Jul 30, 2008
  • Jul 30, 2008
Wisdom comes with age as far as I know, not to say that jrichker is old ; just wiser than the rest of us.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Forced Induction V3 pulley change
  • JD1964
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 21, 2025
JD1964
Tensioner arm bolt
  • brandon4v
  • Jan 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
Belt Tensioner Question...
  • robw13
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2025
gkomo
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
