  • SN95 4.6L Mustang Tech
Tensioner replacement
  • Thread starter Thread starter sarmikgar
  • Start date Start date Sep 15, 2009
sarmikgar
53
Las Vegas
Sep 15, 2009
  • Sep 15, 2009
Cant find any info on it in my manual..
I assume its just the one bolt, just wanted to check if I was correct and if it was regular old lefty loosey or not?
Thanks.
edit:
I did search, but didnt find the exact info I was looking for
T
tonytaylor85
126
Augusta GA
Sep 15, 2009
  • Sep 15, 2009
That's correct. The bolt in the center of the arm will take it off. There is an index pin cast into the back that lines up with a hole in the front cover. If you need to take off the pulley off you can put a 3/8 drive ratchet in the front side where you loosen the belt to hold it while you turn the bolt on the other side. It took me longer than it should have to figure that out so I thought I'd throw it out there. You should have seen me with a giant pair of channel locks trying to get it off. I'm sure the neighbors were laughing!
squeak93
2,345
416
164
Joplin, Missouri
Sep 16, 2009
  • Sep 16, 2009
There should be 3 bolts that hold the tension to the front cover and one bolt that holds the pulley onto the assembly. Easiest way to change the pulley is to loosen the bolt before u take the belt off....
The bolt for the pulley is a left hand tighten (backwards) iirc.
sarmikgar
53
Las Vegas
Sep 16, 2009
  • Sep 16, 2009
Ok, this is why I posted, I found differant information. Was there a change made t the part?
My Haynes manual has nothing on it.
My tensioner is only held on by one bolt that I can see.
squeak93
2,345
416
164
Joplin, Missouri
Sep 16, 2009
  • Sep 16, 2009
It may be different on new edge mustangs.. but I know a 98 gt and an 02 exlpoder 4.6 both use a 3 bolt tensioner set up with a backwards threaded bolt holding the pulley on.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 16, 2009
  • Sep 16, 2009
My 2003 GT uses a single bolt tensioner. Release the tension on the belt and take it off. The tensioner itself is easily removed with one bolt.
If it was my car, I would replace the entrie tensioner (not service the pulley). The spring weakens over time. Installing a new tensioner ensure the spring is as strong as it should be and you will get new bearings in the pulley at the same time.
squeak93
2,345
416
164
Joplin, Missouri
Sep 16, 2009
  • Sep 16, 2009
There you go. I havn't had a 99+ car in 3+ years and don't remember. I do know that the 96-98 cars use a 3 bolt as I described above but obviously the front covers are different.
hotdog71
427
Seattle, Eastside
Sep 16, 2009
  • Sep 16, 2009
Hi,
Would a tensioner cause a squeek when pulling away from a stop? I am getting a belt type squeek when I pull away.
br
T
tonytaylor85
126
Augusta GA
Sep 16, 2009
  • Sep 16, 2009
I really doubt it. You'd be able to hear it at the same RPM regardless of load if it were. You should be able to open the hood with it running and play with the throttle (in park/neutral of course) around the RPM you hear it at to see.
Its probably those Fuzion ZRi's you hear
squeak93
2,345
416
164
Joplin, Missouri
Sep 17, 2009
#10
  • Sep 17, 2009
  • #10
It could be one of the idler pulleys as well. They can "squeak" when going bad. Pretty common and cheap to replace.
Pop the hood, get a long piece of hose and start listening to pulleys, careful to not get into the belt.
hotdog71
427
Seattle, Eastside
Sep 17, 2009
#11
  • Sep 17, 2009
  • #11
Thx for the tips I will check it out when i get a few minutes.
br
L
Engine New guy heater hose question. 85 gt 4bbl.
  • linemech31
  • Jan 17, 2026
Fox 5.0 Mustang Tech Jan 20, 2026
General karthief
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
