Terminator swap into 97 cobra
  • Thread starter Thread starter jfran430
  • Start date Start date Mar 25, 2010
jfran430
36
Connecticut
Mar 25, 2010
  • Mar 25, 2010
Whatsup everyone, first off sorry if i posted in the wrong section but i figured i figured i would get the most looks here. So im in the process of the swap into my 97 cobra now, been doing research and whatnot but nothings better than first hand advice right?? so heres whats done right now
- Engine bay is basically stripped for paint, plus i figured i could put it all back together however i want
- I have a fuel tank and pumps from an 03 ready to go in
- Have a d/s from an 03 with the hybrid u-joint and a buddy making me an 11/16" spacer for it (hes just replicating steedas spacer for me), no problem right?
- I need to relocate just the alternator i believe?
- Motor has the wiring harness on it and i found a thread on converting a 97 from coil packs to COP's by splicing the harness's ( has a full wire diagram i can post the link if thats allowed?) . Isnt that all i'm really doing anyways?
- Was planning on using my stock computer and gauge cluster too as long as i can (once everythings in im just turning her on to make sure theres no vaccum leaks and she idles fine and then its right to the tuner on the trailer)
- Theres also a few other sensor and vaccum line issues i need to worry about
Looking forward to responses and getting this done guys! also in todays iphone world i can post pictures whenever of whatever lol. thanks in advance!!
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Mar 25, 2010
  • Mar 25, 2010
I assume when you said the motor had the wiring harness on it you mean the '97. Yes the alternator pig tail has to be relocated and you may need the Terminator specific plug as well I believe it's different (on the Mach 1 it is different). The TPS sensor pigtail will need to be lengthened as well. Not sure about the EGR and related sensors as I removed all of mine. You should relocate your IAT wiring to the IAT2 location at the back of the blower, for that you will need to lengthen it and buy the IAT2 pigtail. There are no knock sensors on the Terminator engine so you can remove those sensors and leave the plugs where ever you have space. Not sure about the COP conversion.
Bill
jfran430
36
Connecticut
Mar 25, 2010
  • Mar 25, 2010
No I have the whole harness that comes with the 03 motor and tranny. No 03 computer though but I don't think it matters, mine should be fine right? And ok great thanks I'll probably delete my egr as well. This is the COP link
TCCoA Forums - View Single Post - why does my car still run with NO spark plug wires hooked up at all???
I think it'll work but if not I'm sure something along those lines with an msd would do the trick, no?
Mustang92
SN's #1 1%er
Jun 6, 2001
6,467
South Florida
Apr 2, 2010
  • Apr 2, 2010
I'm not sure if your stock PCM is compatible with the 03 harness. The fact that you have the main harness for the 03 means you won't have to do anything wiring wise because it's all the same.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
